Hi,
I have just downloaded your trial version but it makes no mention of the time coded vinyl (infact i think the user guide is for v2 rather than v3). Anyway, I only have one technics deck and want to know if virtual dj will work as if I have two decks. What i mean by that is - is there a switch in VDJ which I can select each time I want my technics (with time coded vinyl) to control either the left or right turnatable in VDJ (depending on which is playing and which I want to cue/drop in at the time).
Hope that makes sense.
Thanks
Thanks
geposted Mon 06 Jun 05 @ 11:15 pm
you must create a keybord shortcut for timecode_active and in the tcv setting set it on a special option.
I'm sorry i don't have VDJ on this computer so i can't really tell you what setting you need.
it's a setting where there are no numbers and i think it says something like music active...
____
P-03
____
P-03
geposted Tue 07 Jun 05 @ 1:24 am
So each time I press this keyboard shortcut my technics will be switched to control the other VDJ deck... and so on?
Cool. Really glad VDJ has this feature ;-)
Thanks.
Thanks.
geposted Tue 07 Jun 05 @ 9:53 am
