Hi there! i have a trouble now and need your opinion!!! i wanna get a new good hard drive now, i surfed the internet and found this 250GB 2.5" SATA Laptop Hard Drive , i think it is quite well, but i don't know how is it really! I need your opinion! How do you think about it???
http://www.dealstudio.com/searchdeals.php?type=id&q=d176793&ru=290583
geposted Tue 27 Jul 10 @ 1:22 am
That is another thing not a single drive. You may found 500GB cheaper than that.
This one is 640GB HP and for just $79
http://www.newegg.com/Product/Product.aspx?Item=N82E16822332093
Seagate 500GB for $89
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148346
geposted Tue 27 Jul 10 @ 5:29 am
Tip. Its hard to find a small size HD with external power but if you dont care about size go for the big ones.
Just remember to format your new HD and get rid of those useless software that comes with, before you fill it with your music files.
geposted Tue 27 Jul 10 @ 7:36 pm
