guys i have a music dvd vob and cant understand which file is which.im trying to find out if i can convert it to mp3 for my car thanks.
forgot to say for mac os
geposted Tue 27 Jul 10 @ 2:15 pm
Hey mate, if you use a programme like "Nero" it will do it for you, just drag your files into the window for mp3s' and it will just take the audio out for you. Thats just one of probably a dozen your gonna get... lol
geposted Tue 27 Jul 10 @ 2:30 pm
lol paul.
thing is when open the dvd so many ie number 1s come up ect which one do i drag.
hate this sort of stuff.
tayla got a projector with rear view do i need a special screen.(hijacking my own thread lol)
geposted Tue 27 Jul 10 @ 2:33 pm
Play the file in Virtual Dj and use the record feature.
or google VOB to mp3 and you see a long list of softwares that can do this for you.
geposted Tue 27 Jul 10 @ 3:26 pm
mate its a long play concert so want to split them also.will try play in vdj and see if i can split them
geposted Tue 27 Jul 10 @ 3:31 pm
Check out - Need for Software. Thats what it is called. I use it all the time. You will see what I'm talking about. Amazing software!
geposted Tue 27 Jul 10 @ 10:54 pm
You need a screen that made for rear projection, or one that will do both, rear and front. You projector will only project from the rear? Most have the ability to do front and rear.
geposted Wed 28 Jul 10 @ 11:01 am
you need a material similar to spandex/lycra (just like your stage costume greg, lol) for rear projection.
Best get it in white though mate... lol
geposted Wed 28 Jul 10 @ 11:40 am
LOVE the example tayla, makes me want to run out and get "spandex"
geposted Wed 28 Jul 10 @ 12:20 pm
lol paul.
projector does front and rear.
tried playing dvd through and couldnt hear a thing crackly and terrible sound.really dont understand codecs
geposted Fri 30 Jul 10 @ 1:11 pm
i gotta new screen w/ leopard spotted spandex and now my videos are
ALL MESSED UP !
this software SUX !
ALL MESSED UP !
this software SUX !
geposted Fri 30 Jul 10 @ 3:03 pm
chuck post a problem it can be solved lol.just show female vids with the leopard skin and away you go.bet ya those idiots jedward would be a good vid on your screen
geposted Sat 31 Jul 10 @ 3:12 am
