Hi,
I recorded about 4 samples for loops. I set up the samples the exact way the default samples are configured (Loop, Match Pitch, BeatLock, Sync on Beat are all checked off) but they do not sync with the song that is playing. The default samples all work correctly. Could it be that the the BPM for the songs that I sampled from were not read correctly by the software?
geposted Tue 27 Jul 10 @ 2:53 pm
Has anyone else had this issue?....if so..how did you resolve it? My samples aren't recording at the bpm that I recorded them at. Not sure if that is how it is supposed to be, but kinda inappropriate to insert a lower bpm sample into a higher bpm song, especially if it's the same song.
using vdj6pro
herc rmx updated drivers and firmware
win7
using vdj6pro
win7
geposted Tue 21 Dec 10 @ 11:11 pm
