Ok guys i have a NEW Macbook Pro running the latest software and NEW Virtual 6.8 with a Hercules Mk4 Midi controller. In the video screen of virutal, There are 3 windows a small left, A small right and a Main in the middle, I have my mini dvi to vga hooked up to a video converter so i can put the video on alot of screens in the club, all hook threw the rca and a/b switches. But that is not my problem.
The problem is that the videos are Mp4 and on any other computer or even this mac they look crystal clear, when i put them on w/virutal the main video looks very dark and faded. the one in the small left or right box look bright, what is the problem?
geposted Tue 27 Jul 10 @ 4:19 pm
Silly question, but is the video transition set to fade and the video fader in the middle? What skin are you using and what is your setup?
geposted Tue 27 Jul 10 @ 5:50 pm
you have the fade on volume checked in the config.
geposted Tue 27 Jul 10 @ 11:30 pm
I have 6.0.8 and using the reg 6 skin. Not high. And i had the fade to black checked off, I have to try it tomorrow to see if it works to uncheck, Also is there a reason if i DO NOT have the mini dvi connected and i load a vid it says error on video driver? And what is the best way to get videos on more than 3 screens if the club i work at only has an rca input on the back of a vcr and A/B switchs. So i have to use a VGA converter with an rca plug, So the quality is not really that good, are there any other choices?
geposted Wed 28 Jul 10 @ 2:29 am
