i just downloaded the trial before i but the tables and the songs are not playing smoothly its coppy anyone know why
geposted Wed 28 Jul 10 @ 9:56 pm
What is your system specs?
you can try the following:
1) play with the window size. (if stretched it can be choppy)
2) Lower your performance Settings (move the tab all the way to the left)
3) Change the soundcard to the actual hardware and not primary (in sound setup)
geposted Thu 29 Jul 10 @ 12:51 am
you didn't give any information about your system
there are minimum requirements your system must meet
what is your operating system and how much ram
what is your VDJ version number, did it come with a controller ?
if your system meets the minimum requirements then there are a number of fairly standard tweaks
you may have to do in order to get it to work right , some are settings for the software , some are settings in Windows ,
if you use windows , so far we don't even know that .....
geposted Thu 29 Jul 10 @ 6:21 am
