Hello everyone I'm trying to figure out a way to make a midi key toggle a deck between timecode on and off. Usually I'm good with this type of thing but this one is proving to be rather difficult. Can anyone help me out with this? Thanks!
-L
-L
geposted Fri 30 Jul 10 @ 12:14 am
Try this " deck 1 timecode_bypass" and " deck 2 timecode_bypass"
Hope that helps
Huey
Hope that helps
Huey
geposted Fri 30 Jul 10 @ 12:53 am
If you are assigning it to a button that is present on both sides of the RMX, simply assign it to:
timecode_bypass
You will then be able to turn it on/off independently for each deck.
timecode_bypass
geposted Fri 30 Jul 10 @ 12:11 pm
hmm thats what I was trying, but i was assigning it to a button on my NanoKontrol, maybe I have the CC#'s wrong, ill go through it all again and let you know how it turns out, thanks for the help!
-L
-L
geposted Fri 30 Jul 10 @ 2:10 pm
Still can't get it to work. I've tried everything from "deck 1 timecode_bypass" to "timecode_active" and even "toggle timecode_active" Is it possible it wont work due to there being buttons for it on my skin? Its not a huge issue because i can click it on and off but its a hassle using the mouse sometime and much slower. The reason I need it off is because When I layer effects with the timecode on sometimes it glitches, but when the timecode is off I can stack so many without a problem.
I also tried clicking learn key, action, and then clicking the timecode button on my skin and it spits out this "timecode_Bypass blink & timecode_active : timecode_active" The skin is Cue_RMX by cioce v2.3
geposted Fri 30 Jul 10 @ 4:24 pm
