Hello,
I bought an m-audio xsession pro and I'm attempting to assign VDJ functions to buttons however I'm running into an puzzling problem. If I, for example, set a low EQ nob on the m-audio device to the left mixer low EQ in VDJ, the knob only adjusts the left low EQ provided the left deck is assigned as the PFL. If I assign the right deck as the PFL, the left low EQ knob on the m-audio device then turns the right low EQ knob in VDJ
Is it possible to assign midi-functions that manipulate the left of or right sides of the software deck/mixer regardless to the deck's PFL function being active or not?
Thanks
N
Thanks
N
geposted Fri 30 Jul 10 @ 5:05 pm
You can add deck 1 or deck 2 in front of the action to make it apply to a specific deck, e.g: deck 1 eq_low
geposted Mon 02 Aug 10 @ 12:08 pm
