hi,
is there a way to edit vdj playlists?
example:
i've created a number of playlists based on key using mixed in key as an alternative to the keys set by vdj.
my library of tracks is constantly growing, and as i analyze these tracks in mixed in key, i'd like to add the new tracks
to the existing playlists. i searched the manual and the forums but can't find anything in reference.
any help or maybe a point in the direction of an m3u editing app would be greatly appreciated.
thanks!
example:
thanks!
geposted Fri 30 Jul 10 @ 5:10 pm
You have to load and edit each playlist seperately (at the playlist window, on the right side)
Then simply drag n drop new songs there. After adding, save the playlist using the same name.
geposted Sat 31 Jul 10 @ 10:02 pm
It's a small thing but it'd be nice if the program remembered the name of the playlist you were editing so that when you saved it then you would be prompted that it would overwrite the existing playlist or ask you for the name of the new playlist if it did not exist. Nice to have feature of course...
geposted Mon 16 Aug 10 @ 11:02 am
