Hi,
Is there a way to disable Automix Smart Cut globally?
I would really like a way to make a playlist, select Automix Smart and if the current playing song and the next one can be mixed with Tempo mode, then Tempo mode is used, if not I would like Fade (remove intro/outro) 16s to be used. Basically a global option to allow/disallow Automix Smart modes (Tempo, Cut and Fade)
Is there a way to do that without having to edit each file's BPM and uncheck Allow Cut?
If not, are you planning to add this feature?
Thank you guys, I really enjoy Virtual Dj =)
geposted Fri 30 Jul 10 @ 6:35 pm
currently this is not possible..
You might want to add this idea to the "wishes and new features" forum and see what kind of support you can drum up..
Does anyone know if Mixmeister or OTS has this ability? (they are the two programs built from the ground up to do automixing)
geposted Sat 31 Jul 10 @ 1:33 pm
Great, I didn't know about those programs, I'm gonna give them a try and see what they can do. Thank you
I love Virtual DJ, is the most powerful program to live mix, but sometimes we just want to make a party in a house or something and have a playlist being automatically mixed, so none of us has to be there mixing. We all want to dance all night :P
Too bad VDJ doesn't have this option I'm asking, cause its automix smart feature is really awesome (when not using Cut mode...)
geposted Sat 31 Jul 10 @ 6:26 pm
