should be a plugin
there is precedent ......soniques
also the clipbank should be configured like jingle palette .....
geposted Sat 31 Jul 10 @ 3:23 pm
I actually put it forward as a plugin when I first discovered it, pointing out it was a freeware product. It was on that basis it was rejected as a plugin for VDJ.
Still scratching my head on that one as I thought Soniques, Freeframe and VSTs could all be labelled under that same umbrella.
For me it's a nifty little add on for us guys that use Jingles/Drops in their gigs, I would imagine it's also of benefit for some of the guys who go on Virtual Radio.
This type of software sells for hundreds and others for thousands of Pounds/Dollars on the net with similar functions. You can make up as many pages/palettes as you want and each button can be played for as long as you need, so you can have a 3 second drop or use it to run a 45 minute mix it's up to the user (it will even automix between buttons), plus it will take streams as well. As I said, a nifty little piece of software.
A big plus one on the clipbank idea, but you can get round with multiple clipbanks in the mean time, just not the same though is it... but there may be something in the future... lol.
geposted Mon 02 Aug 10 @ 5:53 am
it's great and i use the "assign jingle" as my headphone feed .....
also the clipbank should look and act like jingle pallet .....
thanks for showing me the multiple clip bank trick ......
geposted Mon 02 Aug 10 @ 7:36 pm
