Im just about to buy a set of stanton STR8150 turntables and a Gemini P5626EFX mixer.
I currently have a Hercules MP3 E2 controller.
I will need a 4 in 4 our sound card but i was wondering if i could integrate my hercules controller into my VDJ timecode set up. Just for selecting tracks and usuing effects and things?
Would appriciate the help.
Thanks
Tom
Thanks
Tom
geposted Sun 01 Aug 10 @ 11:05 am
I don't use controllers but Ive seen that name here a million times. Try doing a search in the hardware forum and I bet you'll get better results.
Sorry I couldn't be more help
Help
Help
geposted Sun 01 Aug 10 @ 11:52 am
You need the full pro version for time code support.
The e2 does not have a sound card, the e4 does.
The Hercules 4+6 Trim would be a good match for this and can be purchased with time codes and the proper software for time code use.
http://www.americanmusical.com/Item--i-KAY-DJTRIM46SCR-LIST
geposted Sun 01 Aug 10 @ 11:55 am
