Is there anyway I can install both 5.02 & 6.1 on my laptop, have the ICONS for both so I can run either version? I want to install (2) different versions of VDJ.
geposted Mon 02 Aug 10 @ 11:18 am
Install 5.02 then go into the Virtual DJ Folder and make a copy of virtualdj.exe and rename it to Virtual DJ 5.02.exe
Install 6.1 then go into the Virtual DJ Folder and make a copy of virtualdj.exe and rename it to Virtual DJ 6.1.exe
Then just create icons for either of the newly created .exe files
geposted Thu 05 Aug 10 @ 5:11 pm
