Hi all,
I have just purchased the pro version of the Virtual DJ however after downloading it, I have gone to use it and an error message comes up which is
Invalid skin file (error line 0 in the xml)
Can anyone help please??
Looking forward to replies,
Thank you!
Thank you!
geposted Mon 02 Aug 10 @ 4:15 pm
You Have Delete Your Old Skin? Try To Download It Again Or download Your Old Skin You Had Before You douwnload Pro.
geposted Mon 02 Aug 10 @ 5:32 pm
Thanks for your advice. Managed to get it working however I cant find any of my tunes on the DJ. Obviously iv looked in itunes etc but it doesnt seem to have transfered them over. Do you know how to resolve this?
Thanks again for your help
geposted Mon 02 Aug 10 @ 6:02 pm
No reinstall needed, you can fix this by clearing the following string value in the registry: HKEY_CURRENT_USER\Software\VirtualDJ\Skin
This string holds the name of the skin that loads at startup. When you clear it, the default skin will load.
Cheers!
Hippo
Cheers!
Hippo
geposted Mon 01 Nov 10 @ 4:21 pm
