My setup:
Technics SL1210 x2
Hercules MK2
Virtual DJ 5.0.7
Serato Time coded Vinyls
Every once in a while, anywhere form half hour to every two hours, the timecodes will stop responding and the only way to fix it is to restart VDJ. I was hoping there was a way to fix this so I don't have to make the switch to Serato or Traktor. Also, When I configure my timecodes, there is no "noisemap" option, just VDJ default engine option and it appears in a Sine wave. I'm very frustrated and need to fix this before Saturday. Any tips? Thanks
-DJ Savant
Technics SL1210 x2
Hercules MK2
Virtual DJ 5.0.7
-DJ Savant
geposted Mon 02 Aug 10 @ 6:15 pm
VDJ 5.07 is pretty old and many changes and imporvements have been made since to the timecode engine, so an update would be recommanded.
Are you also using the latest drivers for your DJ Console ?
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=177&cid=1
As well, you may want to apply the USB related optimizations suggested in this guide:
http://ts.hercules.com/faqs/eng/her_eng_00364.pdf
geposted Wed 04 Aug 10 @ 7:56 am
Hi, I too have had this similar problem, Timecodes stop responding I go back into the config and just re-apply the timecode config and it works again don't have to leave VV, I am running Virtual Vinyl 6.1.2 from numark also have the Numark VV box and Timecodes, Technics 1200SLMK2, Windows 7...Numark has not been any help I don't think they know this product quite well when I do get a response they direct me to their download area and suggest I take a look there. I will look into my usb config haven't changed any settings there.
geposted Wed 22 Sep 10 @ 10:39 pm
