I want to uninstall and reinstall VDJ......what steps do I need to do to back up my saved playlist? I am thinking I can just copy the vdj folder from my documents and save the contents to be used later, will that work? I would hate to lose all of my playlist! Thanks in advance!
geposted Tue 03 Aug 10 @ 3:20 pm
As long as you do not change any path of your mp3s - then this will work.
Greets, Heiko
Greets, Heiko
geposted Tue 03 Aug 10 @ 3:22 pm
Thanks! Your the man!!!!!!
geposted Tue 03 Aug 10 @ 3:28 pm
