Setup:
2 Serato CV-02 B side
2 Technics M5G
DJM-909
Using the RMX as the ASIO soundcard with input switches set to phono
I believe that my set up is correct and my timecode "circles" are good but every 5 to 10 seconds, the tracking drops from 100% down to as low as 30% for a split second. I am wondering if this is normal or should I still be tweaking my latency settings some more. The Hercules audio buffer is set to 11ms and VDJ buffer is set to Auto right now (overall performace slider is to the far left).
2 Technics M5G
DJM-909
geposted Tue 03 Aug 10 @ 7:35 pm
Correction...Hercules audio buffer is set to 10 sec. Also, my speed indicator fluctuates from 0.2 to 1.0. Is this normal?
geposted Wed 04 Aug 10 @ 12:28 am
