where is everybody buying your replacement lamps for your projectors? the price for the same lamp is diffrent on every site.
mine is getting close to 1500 hrs. those things are very expensive.
thanks guys (and gals)
geposted Tue 03 Aug 10 @ 9:25 pm
Greetings,
I go to eBay and sort the database for the best price. The vendors generally list good specs on the lamps. There are usually at least 2 different quality bulbs. The pricing difference is determined by the number of usable hours. You decide how much you want to spend.
It's been a while now that I purchased a spare bulb for my projector. I went with the cheaper one. If I need to use it, next one will be a long life series. Then I'll swap and put the cheap one back in spare status.
Long life to de bulbs.
Regards,
JimJamz
Regards,
JimJamz
geposted Wed 04 Aug 10 @ 3:54 pm
thanks jim.
geposted Wed 04 Aug 10 @ 6:20 pm
One of mine is on about the same hours as yours and to tell the truth with the average bulb costing around the £200 price tag ($300) and sometimes more, I'll be doing another upgrade to a new projector that has a bulb life of 6,000 - 8,000 hours. More economical in the long run.
geposted Wed 04 Aug 10 @ 6:45 pm
i would like to do this but i like the one i got , and i feel very comfortable with it. it's an old school mitsubishi that cost $2500.00 new. it came with a spare lamp. the original one finally blew after 5 years.(i reset the bulb life twice) now i don't have a backup. for the cost of lamps it's almost cheaper to buy another projector than buy a lamp. (just like printers that cost next to nothing, but the ink is very expensive) i don't like it when a light bulb is a major purchase.
geposted Thu 05 Aug 10 @ 8:28 pm
