Okay so I recently purchased a ns7fx and I have been having a issue with the crossfader it is not that big of a deal unless I want to scratch and I only do that for fun sometimes so it isn't a big problem. The problem I've been having is lets say I have a song playing on deck A and and no song playing on deck B and the crossfader is all the way over on deck A if I bring it over all the way to deck B the sound keeps playing for about 3 seconds then cuts out. The weird part is it does not do this if I have a track playing on deck B and nothing is playing on deck A and the crossfader is all the way over at deck B and i move it all the way to deck A it cuts out instantly like it should. I really don't know why it is doing this it can't be latency because it would cut out after 3 seconds on both sides right? And also it does not do this in itch so I don't think it is the crossfader bleeding on one side either. Does anybody have an answer or could help me out. I also put this in the numark thread but am trying to see if I can get an answer faster here
geposted Tue 03 Aug 10 @ 11:33 pm
Take a look in what position is your crossfader curve button. Shold be on half.
Regards Tjeck
Regards Tjeck
geposted Wed 04 Aug 10 @ 9:17 am
it is but it still bleeds for 3 seconds when i bring it to deck B but like i said not a big problem so it's ok.
geposted Wed 04 Aug 10 @ 12:49 pm
Uncheck safe mode and check the latency of the NS7 control panel. The higher the latency, is the worse the delay. I can't get below 256, so do go nut.s 512 should be good, I used that for a while before my new PC.
geposted Thu 05 Aug 10 @ 9:52 pm
Also, is there a lag between the controler crossfader and the crossfader on the screen?
geposted Fri 06 Aug 10 @ 6:25 am
no its at 128 and works fine on my computer no problems on deck a just deck b
geposted Fri 06 Aug 10 @ 8:53 pm
