Is there an effect where as you video crossfade from A to B, it divides the number of pixels more and more until you get to 50% then u have nothing of vid A, then over 50% you get the opposite, starts vid B at 0 pixels and then adds more and more until 100% plays vid normal??
geposted Wed 04 Aug 10 @ 12:29 pm
Go here, https://virtualdj.com/forums/128213/Virtual_DJ_Plugins/FreeFrame_Plugins_____________Download.html, you might find something close to what your lookin for. Although none of those are transitions there just effects, but they are badass. Let me know if you like them!!
Hope this helps
Huey
Hope this helps
Huey
geposted Wed 04 Aug 10 @ 12:46 pm
Thanks Beatbreaker..
I got as many free frame plugins and soniques as i can put up with in a night, but its a TRANSITION that im looking for.
saw the effect on a youtube video and ARMADA recods used something like it to make their logo dissapear..
I should learn how to make use of the SDK in my spare time and create my own transition (",)
cant be that hard to do..
geposted Wed 04 Aug 10 @ 12:53 pm
I think Scott has a transition like what your looking except its squares. If I'm right you can adjust how there are. I'm not for sure though. Anyways happy hunting.
Huey
Huey
geposted Wed 04 Aug 10 @ 1:09 pm
