hi can anyone tell me if theres anything really obvious im overlooking, i have all my songs on an external hdd, and while trying to get vdj working correctly ive done numerous windows 7 clean re installs, but before i did i copied all of my vdj files onto a flash drive.
now ive reinstalled vdj back off the flash drive all my cue points are missing.
does vdj save these to drive c or the external hdd? and is there a way to get my cue points back?
if i go back into browser > database it only picks up drive c even though externall hdd f: is shown in the left pane?
geposted Wed 04 Aug 10 @ 4:05 pm
All the data VDJ collects (tags, cue points, BPM's, etc etc) are all stored in .XML databases
The primary one is stored in my documents/virtual DJ
if you also use an external drive a .xml database will be created on that drive (allowing you to hot swap your drives between computers)
geposted Thu 05 Aug 10 @ 3:32 pm
ok thanks for that.
well having had a look my hard drive has virtual dj local database v6 on it, then says xml files.
but vdj still doesnt pick up drive f in the database and still no cue points......
geposted Thu 05 Aug 10 @ 4:13 pm
did you save/backup the original .xml database files BEFORE you re-installed windows?
geposted Fri 06 Aug 10 @ 9:51 am
i dragged the entire vdj folder across from drive c to my flash drive, so i assumed everything would come with it. i compared what i had on my flash drive to that i had on drive c, then reinstalled windows 7, dragged everything back across onto drive c?
geposted Fri 06 Aug 10 @ 1:15 pm
i also have, like you say, a local database on drive c and f.
geposted Fri 06 Aug 10 @ 1:16 pm
