When i first go to a file,the songs are in order of "most" played..If i click on artist or track,that of course comes up//how do i return to the most played songs in each file?Thanks!
geposted Thu 05 Aug 10 @ 3:31 pm
ron29jen wrote :
When i first go to a file....
you mean folder... right?
You have to enable a column with Play Count info. Just rightclick to any of the showing browser columns and enable the one called PLay Count. Then you can simply order your files according to most played.
geposted Thu 05 Aug 10 @ 3:36 pm
Well i think he is talking about the "smart short"
Just click on this little area ... so simple !!!
geposted Thu 05 Aug 10 @ 4:39 pm
Yes thats it!!That little box!It helps me quickly find the most played "money" songs,the songs i use a lot,thank you very much!
geposted Thu 05 Aug 10 @ 4:47 pm
This is one of these unique -golden- virtualdj features. Helps you to totally and dynamically personalize the browser view.
Some users may not know this little trick, that's why i posted the screenshot !!!
geposted Thu 05 Aug 10 @ 5:00 pm
