Not doing anything.... Cough...Cough... QUE, PLAY, A LOT OF CLICK, CLICK, :) BUTTONS... (the most important buttons)
Then.... LOAD, QUE POINTS, PITCH RESET BUTTON works (hmm...?!?)
Any fixes yet?
Any fixes yet?
geposted Thu 05 Aug 10 @ 11:40 pm
The fix is to go back to the previous version. If you don't have it raise a support ticket and it will get added to your download centre.
geposted Fri 06 Aug 10 @ 1:14 am
Correct... does not work in 6.1
I had to go back to 6.07
geposted Fri 06 Aug 10 @ 7:47 am
Use 6.0.8 And They Will Work That Out Soon.
geposted Fri 06 Aug 10 @ 11:09 am
6.1 does in fact work, but 6.1.1 does not.
Prior to installing ANY new VDJ, I backup the old exe and label as such. Then place shortcut on desktop.
Plus I have EVERY update from 3.x tucked away.
geposted Fri 06 Aug 10 @ 12:01 pm
