Topic: Custom keyboard layout help
Hey, qustion concerning customizing keyboards. I am removing all the shortcuts that i will not use but I am trying to create 3 shortcuts that i cannot find. Since i am using the full video skin in 6.1 trial edition, I am looking to configure 3 keys for audio only, video only and karaoke only to replace the function of the browser button on the far right. Problem is i cannot find these actions on the menu to add the keys i want to them.
what I wold like to do is as follows:
assign;
"Print Screen" Key to "Show Music" hit once to show and once to remove
"Scroll lock" key to "Show Video" same action as above
"Pause break" Key to "Show Karaoke" same action as above
I am keeping only the f keys for the sampler and deleting everything else. I am used to the PCDJ VJ 5.2 skin and everything runs except i have no menu select buttons so until I can purchase 6.1 and download the skin for it, this is my alternative move.
Any help at all would be appreciated. TIA
geposted Fri 06 Aug 10 @ 2:20 am
One more thing, How hard is it to change the music icons themselves as i would like to change the icons to be the same as pcdj vj 5.2 as well.
Update: been playing with the xml, got my icons changed, trying to add a sampler and recorder button with no luck and cant get the menu buttons either. keep getting fault in line 0 no matter what and open to suggestions at this point.
