Forum: Old versions
Topic: Cue points in Automix
Hello all. I know how to set and save cue points, but is there a way for those cues to be used during automix. The reasoning is a lot of ripped dvd's that rip in chapters leaves a lot of talking or crowd noise before or after the song. I want to set cues to start or end the song in automix. Thanks for the help.
geposted Fri 06 Aug 10 @ 9:51 pm
https://virtualdj.com/wiki/FORUMFAQ.html
Q:: How do I use 'Cue Points' with the Automix?
A:: The linked thread has some great details
https://virtualdj.com/forums/130910/Wishes_and_new_features/AutoPlay_with_cuepoints.html
In the VDJ User guide
https://virtualdj.com/images/pdf/VirtualDJ6-UserGuide.pdf
Starting on page 15, the manual gives a great overview of how to setup Automix, and how to set the MIX POINTS of each song.
When you engage the "smart" setting of Automix, you can set/use 3 different IN and OUT mix points for the 3 different mix modes - Tempo, Fade, and Cut. Each mix mode has its own mix points (ie: each mode retains its own set of cue points)
