I just got a Numark MixTrack and Virtual DJ Pro. I'm having problems with using multiple effects. I want to have a loop going and add the 'brake' effect at the end of the loop. Then when the loop is playing again add different effects while the brake is still activated in the loop. The problem is whenever I select a new effect from my controller it deactivates the other one. I want to control when the effect is activated and not turn off when I'm trying to select a new one. Any help would be appreciated
geposted Fri 06 Aug 10 @ 10:11 pm
I think the 'effect select' should be used to select the effect, and 'effect active' to toggle if the effect is active. So that way I can select and activate however many effects I like. But no the 'effect select' wants to deactivate the effect when I select another one
geposted Fri 06 Aug 10 @ 10:41 pm
