OK you know when you click on a folder and the sub-folders appear...........can I change what the sub-folders look like as well?? If so can someone PM me the instructions please.
Thanks for your time
Huey
Huey
geposted Sat 07 Aug 10 @ 10:42 am
After checking about 15 other skins I'm assuming that these cant be changed....................or mabay I missing something.
geposted Sat 07 Aug 10 @ 12:13 pm
Can someone verify this for me, please?
Thanks for looking and your time
Huey
Huey
geposted Sun 08 Aug 10 @ 3:02 pm
Also the "Bullseyes" can those be changed?? Cause there kinda boring.....................
geposted Sun 08 Aug 10 @ 4:30 pm
yes you can change your sub folders. i used the program tuneup utilites www.tune-up.com it lets you change all the folders or the folder you want to change. just download icons install with tuneup then just change it. you can also change your windows theme and do some tweaks to your pc.
check here http://s1030.photobucket.com/home/DJOSH956
ex:
here's how my desktop looks with some changes i made with tuneup
btw win vista
ex:
btw win vista
geposted Sun 08 Aug 10 @ 7:34 pm
So the sub folders have nothing to do with VDJ? Those folders icons are based off the windows program itself?
Thanks for looking and you time
Huey
Huey
geposted Sun 08 Aug 10 @ 8:18 pm
glad i could help, no problem....you're right, the sub folders have nothing to do with VDJ. you can download icons online then change them to whatever you like.
geposted Sun 08 Aug 10 @ 9:01 pm
Hahaa! Thanks man, this gonna be so sweet!!
geposted Sun 08 Aug 10 @ 9:30 pm
