Hi, I trying to change the fonts for the widescreen skin on VDJ 6. Thanks to Tyler's tutorial I can get them larger for the elapsed and remaining time, but it cuts the bottom off of the letters. I tried making the gain and pitch fonts smaller but it still cut-off. Also made the author and song titlle smaller. I think it has to do with spacing between song title and elapsed/remaining but I don't know how to change that. Any helps appreciated.
Thanks, Keith
Thanks, Keith
geposted Sat 07 Aug 10 @ 2:47 pm
You have to change the dimensions of the box. I dont know how to explain but I can tell you that youll have to make changes to the skin it self (depending on what skin) aswell as the xml or itll look all weird............download the skin creator found in the download section. Its a little more work then just opening it with notepad.
Good Luck
Huey
Good Luck
Huey
geposted Sat 07 Aug 10 @ 3:40 pm
Thanks Huey, I give a try tomorrow.
Keith
Keith
geposted Sat 07 Aug 10 @ 4:39 pm
