Hey guys... im having some trouble hooking up my turns to vdj. Im using the SL1 interface. It works fine with serato but when I run VDJ and go to the sound setup, I select Timcodes under the "Inputs" tab, External Mixer under the "Outputs" tab, but when I get to the "Sound Cards" tab, Im only able to select 4in-4out. I remember i used to be able to select "SL1" in my windows laptop. Is there something I need to change?
geposted Mon 09 Aug 10 @ 6:23 am
Unfortunately the Rane SL1 and SL3 will not work on a Mac with VirtualDJ because the manufacturer has not made any standard drivers available for it.
SL1 will work on a Windows PC only (Or a Mac running Windows via BootCamp.)
SL3 will not work on a Mac or Windows PC due to lack of drivers.
geposted Mon 09 Aug 10 @ 6:34 am
