Hi All,
Just upgraded to VJ Pro from VJ 5 that came with my RMX. VJ 5 played and worked great. Cannot get Pro to work at all. Screen controller comes up. Can load music but no sound, or beat graph movement. Downloaded Win 7 patch for the RMX.
Am I doing something wrong? Frustrating as I spent $150 beans on this upgrade...........
geposted Mon 09 Aug 10 @ 9:02 pm
Did you go to the configuration tab on vdj and select the Hercules Rmx in the drop window under soundcard? then you should have a Icon with the Vdj logo at the bottom right of your screen.this is the Rmx control panel.select Asio mode.you might have to close and reopen Vdj so it "knows" that its now in Asio mode.also you might have to go to the hercules website and download the latest drivers for the RMX.and allways plug the Rmx FIRST before you open VDJ and wait for the installation to complete (blue Lights quit blinking)then open Vdj.from then on everything should be Good to Go.
geposted Tue 10 Aug 10 @ 3:07 am
Thanks Tracker that was the exact solution. Great job.
geposted Tue 10 Aug 10 @ 5:51 pm
