Faulting application name: virtualdj.exe, version: 5.2.0.0, time stamp: 0x488b4594
Faulting module name: virtualdj.exe, version: 5.2.0.0, time stamp: 0x488b4594
Exception code: 0xc0000005
Fault offset: 0x0009b429
Faulting process id: 0x1324
Faulting application start time: 0x01cb3659a76f0f66
Faulting application path: C:\Program Files (x86)\VirtualDJ\virtualdj.exe
Faulting module path: C:\Program Files (x86)\VirtualDJ\virtualdj.exe
Report Id: 00d4f1cf-a274-11df-885f-b2cbd123dead
any idea
any idea
geposted Tue 10 Aug 10 @ 3:44 am
Please download the latest trial version from this site and try that instead.
geposted Tue 10 Aug 10 @ 4:18 am
but that jpboggis wont work on vdj 6
geposted Tue 10 Aug 10 @ 5:58 am
I assume you have the HC-4500?
You would need to purchase the current version then request a downgrade to 5.2
V6 natively supports that controller and you can map it to your personal liking. Trying to install cracked versions is not the way to go.
geposted Tue 10 Aug 10 @ 7:20 am
