Greetings,
I had asked for this issue to be looked at in the "Wishes" section of this forum a while ago, and haven't gotten a fix.
To reproduce:
Set the Options Performance tab to "Best Quality" because we're going to slow down the song to zero "RPM".
Notice how key stays the same till halfway to zero... from the center indent... then the song goes out of key. It would be ideal for the song to hold key all the way down to zero.
I haven't seen any controls I can map that would prevent this key change. There isn't a problem going from the detent up to 100%. That stays in key fine and dandy.
Any way to fix this with a control I'm missing? Something like Pitch-Slider-Keep-Key 0%-100%
Thanks for all the fine work everybody does on this Forum. Your help is indeed appreciated.
JimJ
P.S. I programmed the VDJscript verb "getfood" (because no DJ should work on an empty stomach) when I hit my "F" key. But nothing comes out. Can I put a variable in like "getfood-meatball-sub" ? Where do I find the snack? I'm hungry now. I already looked inside the case.
To reproduce:
JimJ
geposted Wed 11 Aug 10 @ 12:57 am
