hello
just receive the vms4 , the mapping doesnt work correctly, most of the command specially the mixer doesnt work
any solution? thanks
geposted Wed 11 Aug 10 @ 7:57 am
What exactly doesn't work?, there is a bug with the auto headphones and cue lights but everything else is perfect.
geposted Wed 11 Aug 10 @ 8:17 am
You may want to refer to this thread covering lots of the issues and quirks people have been having :
https://virtualdj.com/forums/132398/Hardware_Technical_Support/American_Audio_VMS4_Discussions.html?page=1
geposted Wed 11 Aug 10 @ 9:40 am
well first the cross fader is inverted, i try to map different dj soft, and it's the same problem even if i use the trigger reverse normal, the mapping for the mixer section doesnt work either
geposted Thu 12 Aug 10 @ 8:26 am
Hello, I'm friend with the same problem, I just bought a vms4, I wonder if you ever solved and give me the solution, wait for it, thanks.
geposted Wed 06 Apr 11 @ 1:07 pm
