Any issues to report anyone?
Particularly interested in feedback from users of snow leopard.
geposted Tue 31 Jan 12 @ 3:58 pm
Hello SBDJ
I have to report this problem with your plugin show logo whit Lion
image flicker out after a few minutes (very high temperature of 75 ° cpu, I increased the cooling rate at 4300 rpm in manual)
I also tried to downgrade to Double Snow Leo, but the problems are more
This is my configuration
MacBook Pro 15 "Intel Core i7 quad-core 2.2 GHz 8GB 1333MHz
SSD 128GB HD-Intel Graphics AMD Radeon HD 3000-6750M with 1GB of GDDR5 memory
Iomega eGo 1TB FireWire800 BlackBelt
Denon DN MC6000
VirtualDJ Pro 7.0.5
OSX 10.7.2 LION
best regards
Erik
Denon DN MC6000
VirtualDJ Pro 7.0.5
OSX 10.7.2 LION
best regards
Erik
geposted Wed 01 Feb 12 @ 11:38 am
@SBDJ I'm having trouble loading some of the .jpg files that work on the windows side..
I'm also still running snow leopard on a late 2011 macbook pro with the i7.
geposted Sat 04 Feb 12 @ 12:57 pm
Clint, can you upload an example file somewhere for me?
geposted Sat 04 Feb 12 @ 8:40 pm
Here ya go. I use show logo to promote the next events and running specials for the bar when I don't have a video for a song.
geposted Sun 05 Feb 12 @ 1:42 am
Wouldn't slideshow be more appropriate for that?
I'll try your image though and see what I get.
geposted Sun 05 Feb 12 @ 10:52 am
Thanks
geposted Sun 05 Feb 12 @ 10:38 pm
Hi SBDJ
have you seen my post
best regards
Erik
best regards
Erik
geposted Mon 06 Feb 12 @ 4:24 am
I have.
Unfortunately I don't have access to Lion to do any testing, but I'm looking into a few other issues so I will see what I can do.
I tested on a far lower spec machine that yours (on SL) and had no such issues.
geposted Mon 06 Feb 12 @ 7:32 am
Hi SBDJ
I am convinced that both the graphics card to give problems (in Slideshow)
Erik
Erik
geposted Mon 06 Feb 12 @ 10:02 am
You mean slideshow gives you trouble too?
geposted Mon 06 Feb 12 @ 12:38 pm
Hi SBDJ
YES ! We have reported in August 24
geposted Tue 07 Feb 12 @ 8:35 am
@DJClint77: The JPEG you've used is saved in progressive format and the image loading library I've used doesn't support progressive JPEG.
I've updated the plugin to give information as to why a file fails to load.
geposted Wed 08 Feb 12 @ 9:59 pm
Thank you SBDJ I will look into this so what is the best format to use for this matter..
geposted Thu 09 Feb 12 @ 8:49 am
JPEG is fine - just has to be saved as non-progressive. Most JPEGs are non-progressive I believe.
My personal preferences would be PNG or TGA.
geposted Thu 09 Feb 12 @ 11:36 am
SBDJ wrote :
ScrollText for Mac isn't too far away now...
I wish I could use this on my February 25 gig so I won't need a second laptop for video interactive games & announcements.
Not pushing you SBDJ... just wishing, lol.
geposted Mon 13 Feb 12 @ 7:19 am
938MyDJ wrote :
Any luck on this one yet?
geposted Tue 28 Feb 12 @ 10:38 pm
A few small 'quirks' left to iron out but it's getting there.
geposted Wed 29 Feb 12 @ 5:39 am
How do you eliminate flicker or shuttering videos while (Show Your Logo) plug in is engaged?
geposted Wed 29 Feb 12 @ 1:52 pm
I've not had that issue personally - what spec is your Mac?
geposted Thu 01 Mar 12 @ 5:51 am
