hi everyone
look i'm having a problem with my recently buyed behringer ufo202 soundcard, i'm trying to timecode my cd players and it works (quality 100%) but it gives me a problem. its an anoying sound comming from the timecode cd
i've done almost everything but it still there
i'm running win7 64bits and asoi4all asio driver
dunno what to do plz help me!!!!
geposted Thu 12 Aug 10 @ 9:59 am
What CD player are you using and witch timecode cd do you have. and your versíon of VDJ?
geposted Thu 12 Aug 10 @ 12:06 pm
i just downloaded the one in the vdj download section i'm using vdj 6.1 trial version to look if it works, but it doesn't.
geposted Thu 12 Aug 10 @ 2:04 pm
oh and the cd player is american audio cdi300
there are two types of timecoded cds. one for lowend cds and one for highend cds. check witch one you downloaded and try the other one. i had the same problem when i tried timecoded with my stanton s-250. i first tried the lowend but ended up whit the highend.
geposted Thu 12 Aug 10 @ 4:00 pm
hey i just downloaded it and it works a little better but i still have the anoying beep behind the music, but now i get 100% quallity
it's getting better someone with another thing to do plz!!
geposted Thu 12 Aug 10 @ 11:12 pm
Is the soundcard connected to a USB Hub or direct to the computer?
geposted Fri 13 Aug 10 @ 2:10 am
Well i think i have figured it out. The soundcard you have UFO202 is for recording Vinyls. It is for Phono not for line. I think you should have the UCA202
geposted Fri 13 Aug 10 @ 2:14 am
it's for both mate it has a switch for phono and line
but don't know what else to do but i think maybe is a problem with the signal it could be too strong¿?
another thing to do
plz!!!
thx
another thing to do
plz!!!
thx
geposted Fri 13 Aug 10 @ 9:32 am
