Can anyone resize a skin for me? I've tried so many times and never get it right!
My laptops native resolution is 1980x1080 and I like using the regualr VDJ6 skin.
Cheers,
Gary
Cheers,
Gary
geposted Fri 13 Aug 10 @ 11:26 am
Hello,
First you will need to download the Skin Resizer Tool: https://virtualdj.com/addons/tools.html
Then go to "Documents/VirtualDJ/Skins" and unzip the VirtualDJ6 skin.
Open the Skin Resizer Tool (should be installed in "Documents/VirtualDJ/Tools")
Open the XML of the 1280x800 skin in the Skin Resizer Tool.
Select the output size of 1980x1080
Select the output filename.
Select "Smart Resize" option
In "Generating" tab, click on "Do the job".
Zip the new skin.
Open the Skin in VirtualDJ.
Zip the new skin.
geposted Fri 13 Aug 10 @ 2:54 pm
I tried and it still hasn't worked for me. At the end when I rezip the file is it just one file I rezip?
Gary
Gary
geposted Fri 13 Aug 10 @ 4:36 pm
No ZIP BOTH in the SAME Folder...........
Huey
Huey
geposted Fri 13 Aug 10 @ 4:57 pm
Sorted, cheers guys.
Gary
Gary
geposted Fri 13 Aug 10 @ 5:23 pm
