Jus bought a mk2 second hand and have a laptop with vista. Installed drivers and virtual dj but controller doesn't work. Cud someone run me through step by step what settings I need to sort on laptop and controller.
Much appreciated.
Nick.
Much appreciated.
Nick.
geposted Fri 13 Aug 10 @ 1:29 pm
You could start by making sure your console is installed correctly:
http://ts.hercules.com/faqs/eng/her_eng_00265.pdf
If this is the case, you can then confirm that it work as a controller:
http://ts.hercules.com/faqs/eng/her_eng_00302.pdf
If all this seems fine, then , let's have a look at Virtual DJ.
Do you know which version you installed ?
For Windows Vista, it requires version 3.4.1 or higher.
geposted Fri 13 Aug 10 @ 2:05 pm
It's version 3.01... Does that mean the controller won't work with the virtual DJ?
geposted Fri 13 Aug 10 @ 2:24 pm
