Ok i need some help here. I tried this once before with no luck. I know a couple of people were trying something similar or the same.
I want to know if there is any way to use my xponent (all the funtions and knobs) as my mixer and my 1200's for my time codes.
Using torq, i could do this, but I much rather use VDJ.
Right now I have the xponent, conective, and my 1200's that I want to use all togeather.
Any and all help will be great. Thanks.
geposted Mon 16 Aug 10 @ 2:38 am
Anybody?
geposted Wed 18 Aug 10 @ 1:11 am
DJ Ton-E
You could try this. 1. Setup vdj like you would for time code with the conective and also turn on the xponent in Controller tab.
If not try this. 2. Setup vdj like you would for time code with the conective try to midi map the xponent. If you OS is not xp the
xponent will not work right after v5.2.1 (IF YOUR OS IS VISTA OR WIN 7 WITH VDJ V6.0 AND UP THE XPONENT DOES NOT CLOSE
RIGHT.)
RIGHT.)
geposted Wed 18 Aug 10 @ 9:18 am
audio000 thanks for the heads up, I'll give it a try.
Vista/Windows 7 and VDJ, well yeah I am about 50/50 with it closing right.
geposted Wed 18 Aug 10 @ 11:24 pm
