i have to bring it back to the middle just to get it to move most of the time...
.anybody know why that is?
geposted Mon 16 Aug 10 @ 3:40 pm
If you have pitch reset on load active that's normal... Your pitch resets each time you load a new song and the controller must catch up the software...
geposted Mon 16 Aug 10 @ 4:45 pm
geposted Mon 16 Aug 10 @ 5:54 pm
cool..thanks guys
geposted Tue 17 Aug 10 @ 3:27 pm
Even if you use sync your stuffed then despite altering the settings in config.
I get this and it's annoying, a pitch reset button on your controller is a good way to sort this as sliding the pitch back and fourth on the fly is a bit dangerous.
geposted Tue 17 Aug 10 @ 3:50 pm
Another option in VitualDJ Pro is to change the mapping (CONFIG -> Mappers) of the pitch slider to pitch_relative instead of pitch_slider.
geposted Tue 17 Aug 10 @ 7:31 pm
Can show_text be updated to support ``?
The following does not currently work:
show_text "get text 'You are listening to `get loaded_song "title"` at `volume` volume."
Also, if the message is longer than the actual text display (As in the case of the above), the scrolling position starts from the wrong place.
Calling show_text should reset the scroll position back to 0.
geposted Tue 17 Aug 10 @ 7:34 pm
