I use the above skin and have recently brought a 19" touchscreen monitor which has made using the 4 cue point buttons on each deck a bit difficult.
Is it possible to make them bigger and move them down each side of the preview screen?
Should that be possible for a programming novice (me) to do using the Skin Creator Tool v2.3.1 or does it have to be done through/by the original creator.
geposted Mon 16 Aug 10 @ 4:35 pm
Should be easy enough to do with the Skjn Creator and an image editing program.
However you will need the original creators permission to publish any changes.
geposted Mon 16 Aug 10 @ 5:40 pm
I've found here a verry good programm to design a skin with simple shapes where you are able to input some effects... it's used for VSTi in normal case but ive designed allready a skin with it and it works realy good.... maybe i'm able to give you some examples next time, but here is the link:
http://www.g200kg.com/en/software/skinman.html
C.Hackl
C.Hackl
geposted Tue 17 Aug 10 @ 12:21 am
@Chackl,
Nice find bro!!
Nice find bro!!
geposted Tue 17 Aug 10 @ 12:24 am
