Topic: compression/limiter for karaoke
I use a 4 mic wireless setup each has its own channel on the mixer. I want to get a limiter that can handle all 4 channels.
I've never used a limiter before so I am looking for some suggestions on what I should get.
Thanks
geposted Mon 16 Aug 10 @ 10:06 pm
I use a Behringer 4ch compressor limiter along a 4 mic unit, the Vocopro UHF-5800. Instead of individual mic channels I use combined (unbalanced) signal into one of the compressor channels. This mainly because I only have 2 Mic inputs into my mixer.
heres the compressor limiter that I have:
http://pro-audio.musiciansfriend.com/product/Behringer-MULTICOM-PROXL-MDX4600-Processor?sku=182474
Setting the unit is a bit tricky at first but once you have it set theres no need to touch it. Basicly you just need to set where you want the trigger (when the compressor portion kicks into action), the slope or compression ratio (2:1 or 4:1), the limiter. I've found that I never reach the limiter.
Your singers will love how they sound. Most karaoke hosts in my area dont use compressors and people always say they sound better on my equipment.
I have the same mics. Would you be able to possibly give me a screen shot of your settings on your behringer to give me a rough idea of how it works. I've never messed with a compressor/limiter before.
Thanks
