I'm having a weird issue that I hope someone can shed some light on..
I'm using Virtual DJ Pro 6, the BCD3000 gets recognized by my laptop (BCD control panel opens up and everything) and the controls on the BCD3000 all work flawlessly within the program!
The problem lies with the built in sound card.. The midi controls work fine but in the sound setup it doesn't list the BCD3000 as a sound card it lists a BCD2000! If I select that I get "Error in the ASIO sound driver error", if I select ASIO DRIVER > BCD3000 ASIO it crashes the program.. it lists the BCD3000 under the 'mapper' control so wtf?
Someone help please I can play through my laptops speakers but I want to be able to use the headphones to cue!
Thanks!
Thanks!
geposted Tue 17 Aug 10 @ 12:09 am
uninstall ALL ASIO Drivers
Download the latest Driver for the BCD3000
and try again.
and try again.
geposted Tue 17 Aug 10 @ 9:41 am
I uninstalled everything asio as well as virtual dj and did a clean install.. no dice..
I tried installing it on 3 different computers, and it always appears as the bcd2000 instead of the 3000
I noticed something though, in all 3 instances the first time I run virtual dj with the bcd3000 connected I can pick the bcd2000 and it works, but if I shut down the program and try booting virtual dj back up I get an asio error and picking the bcd2000 as my sound card will crash virtual dj
Even rebooting the computer doesn't help, the only way to get it working again is to uninstall virtual dj and reinstall it.
I've tried this on 2 64 bit vista computer and 1 32 bit vista laptop
Help!
Help!
geposted Wed 18 Aug 10 @ 7:00 pm
