PARAM1:
page "sampler" ? deck left sampler volume : page "effects" ? show_pluginpage "Sound Effects" ? deck left effect active ? deck left effect slider 1 : deck right effect active ? deck right effect slider 1 : effect slider 1 : show_pluginpage "Video Effects" ? video_fx_slider 1 : show_pluginpage "Video Transitions" ? video_transition_slider 1 : nothing : page "record" ? nothing : video_transition ? video_transition_slider : var '$shift' ? video_transition_slider : video_transition_select
PARAM1_BTN:
page "sampler" ? var '$shift' ? deck left sampler play_stutter : deck left sampler play_stop : page "effects" ? show_pluginpage "Sound Effects" ? deck left effect active : show_pluginpage "Video Effects" ? deck left video_fx : show_pluginpage "Video Transitions" ? deck left video_transition : nothing : page "record" ? nothing : video_transition
PARAM2:
page "sampler" ? deck right sampler volume : page "effects" ? show_pluginpage "Sound Effects" ? deck left effect active ? deck left effect slider 2 : deck right effect active ? deck right effect slider 2 : effect slider 2 : show_pluginpage "Video Effects" ? video_fx_slider 2 : show_pluginpage "Video Transitions" ? video_transition_slider 2 : nothing : page "record" ? nothing : video_fx ? video_fx_slider : var '$shift' ? video_fx_slider : video_fx_select
PARAM2_BTN:
page "sampler" ? var '$shift' ? deck right sampler play_stutter : deck right sampler play_stop : page "effects" ? show_pluginpage "Sound Effects" ? deck right effect active : show_pluginpage "Video Effects" ? deck right video_fx : show_pluginpage "Video Transitions" ? deck right video_transition : nothing : page "record" ? nothing : video_fx
Ich würde gerne mit PARAM1+2 die Lautstärke der Sampler regeln.
Obwohl bei PARAM1+2 was von "deck left/right sampler volume" steht funktioniert es aber nicht.
Vor dem Problem mit der 3dx9_33.dll funktionierte es, jetzt nicht mehr.
Wer kann helfen?
McFly
PS: Was heißt "_BTN"?
PARAM1_BTN:
PARAM2:
PARAM2_BTN:
Wer kann helfen?
McFly
geposted Thu 01 Aug 13 @ 4:42 pm
"_BTN" ==> Button
Manche Drehregler kann man auch drücken - Taster Funktion.
geposted Thu 01 Aug 13 @ 11:15 pm
jakovski wrote :
"_BTN" ==> Button
Okay, Danke!
Habe alles raus gelöscht und nur noch folgendes stehen:
PARAM2:
Aber leider kann ich die Lautstärke des Samplers immer noch nicht regeln.
Jemand 'ne Idee?
McFly
geposted Fri 02 Aug 13 @ 5:29 pm
Wie kann ich denn denn den Automix Punkt mit der MC 6000 verschieben? Mit der Maus ist das ja kein Problem ...
Endpunkt zunächst verschieben und dann den Startpunkt verschieben?
geposted Sun 04 Aug 13 @ 1:51 pm
zu dem _BTN. das sind der button unter dem Regler.
zu deinem Sampler Volumen ... mach mal das (ist zwar nicht die schönste lösung aber danmit kannst du das volumen alles samples mit einmal verändern
page "sampler" ? sampler 1 volume & sampler 2 volume & sampler 3 volume & sampler 4 volume & sampler 5 volume & sampler 6 volume & sampler 7 volume & sampler 8 volume & sampler 9 volume & sampler 10 volume & sampler 11 volume & sampler 12 volume
mit den Automix punkten habe ich leider kein plan.
geposted Sun 04 Aug 13 @ 2:39 pm
du kannst mit dem Befehl " automix_skip" an der aktuellen Stelle an der dein Track gerade steht, einen Mixpunkt setzen, ob man der aber zusätzlich noch verschieben kann, da bin ich (im Moment) überfragt
geposted Sun 04 Aug 13 @ 4:08 pm
Okay, ich probier's aus.
Ich danke Dir!
McFly
geposted Sun 04 Aug 13 @ 4:20 pm
Ich danke Dir!
McFly
Ich danke Dir!
McFly
Mist, geht nicht, da muß noch was anderes faul sein :-(
McFly
geposted Sun 04 Aug 13 @ 5:31 pm
Kann auch nicht gehen, da die Synthax falsch ist.
Versuche es mal mit dem Befehl:
page "sampler" ? sampler 1 volume & sampler 2 volume & sampler 3 volume & sampler 4 volume & sampler 5 volume & sampler 6 volume & sampler 7 volume & sampler 8 volume & sampler 9 volume & sampler 10 volume & sampler 11 volume & sampler 12 volume : nothing
geposted Mon 05 Aug 13 @ 2:22 am
:D oja das habe ich vergessen ;) danke PachN
geposted Mon 05 Aug 13 @ 2:48 pm
Hab's eben auf meinen beiden Laptops probiert und es funktioniert nicht :-(
Vor dieser Fehlermeldung: "virtualdj_pro.exe Systemfehler .... 3dx9_33.dll fehlt auf ihrem Computer" funktionierte es.
Habe dann die dll-Datei in die entsprechenden Ordner kopiert, Fehlermeldung kommt nicht mehr, aber dafür funktioniert die Lautstärkeregelung
über PARAM.1+2 nicht mehr.
McFly
geposted Mon 05 Aug 13 @ 3:30 pm
Hi Leute,
welches Case könnt Ihr mir für den Denon empfehlen?
VG
VG
geposted Tue 06 Aug 13 @ 4:11 am
Die meisten haben dieses:
http://www.thomann.de/de/magma_dj_controller_mc_6000.htm
LG Stefan
LG Stefan
geposted Tue 06 Aug 13 @ 6:36 am
McFly
McFly
Hat da jemand vielleicht 'ne Idee?
Bin ich mal wieder der Einzige der diese Problem hat :-(
McFly
geposted Tue 06 Aug 13 @ 3:32 pm
Wie bereits geschrieben DirectX 9.xx neu aufspielen. Wenn das nicht klappt würde ich da mal schauen was das Problem ist. Klingt für mich eher nach einer Windows Problematik. Hat ja sonst bisher bei jedem geklappt mit dem Aufspielen.
geposted Tue 06 Aug 13 @ 11:51 pm
Hallo,
Frage in die Runde:
Wie regelt Ihr das beim MC6000 hinsichtlich Balance-Regelung?
Da git es ja keinen Regler für?
Macht ihr das über ein zwischengeschaltetes Gerät?
Oder gibt es da etwa ein Plugin für die Software?
Danke für Antwort.
Gruß
Christian
Frage in die Runde:
Danke für Antwort.
Gruß
Christian
geposted Mon 19 Aug 13 @ 4:21 pm
a-fuchs wrote :
Hallo,
Frage in die Runde:
Danke für Antwort.
Gruß
Christian
Frage in die Runde:
Danke für Antwort.
Gruß
Christian
Habe bis jetzt nie eine Balance Regelung vermisst, so das ich diese bei der MC6000 auch nicht brauche.
Für welchen Zweck bräuchtest du die Balance?
Zwischengeräte nur wegen der Balance? Würde ich nicht machen.
geposted Mon 19 Aug 13 @ 5:54 pm
Da das Gerät ja nun schon etwas länger auf dem Markt ist, hoffe ich hier die Antworten auf meine Fragen zu bekommen.
Wie kann ich die Kanalbelegung bei dem MC 6000 verändern?
Ich benutze den Swap 4 Deck Skin, bei diesem sind die Kanäle schon genauso angelegt wie ich es gerne hätte und am meisten Sinn macht.
Deck 1+2 innere Kanalfader - Deck 3+4 äußere Kanalfader
Leider kann ich diese so nicht auf den Controller übertragen.
Weiß jemand wie ich die Kanalansteuerung verändern kann?
VDJ 7.4 Pro
Win XP
VDJ 7.4 Pro
Win XP
geposted Tue 20 Aug 13 @ 4:17 am
Installiere dir mal diesen Mapper:
https://virtualdj.com/addons/12744/DN-MC6000_Ch_3_1_L-R_2_4_Mapper.html
geposted Tue 20 Aug 13 @ 4:19 am
DANKE
geposted Tue 20 Aug 13 @ 8:45 am
