Well I've cracked the other issue I left a post on with great apprication to the help I got from this forum; million times better help here than the American Audio forum.
Now I hope someone could offer some more insight into the problem I seem to have stumbles across now.
My SYNC button when the track is in loop does not keep the track in sync after its 1st loop, it used to keep it in sync for endless continues looping, now it does not.
If the tracks are not in loop then the SYNC button works as it should.
Has anyone got an idea what this could be, I've heard the software controls the sync not the controller.
Thank you for any advice you can provide. I wish I wasn't but am now finding myslef slowly losing patience with the VMS4.
geposted Tue 17 Aug 10 @ 1:59 pm
Have you got the VMS4 in smart loop mode?
I had this issue and it was because of this. Press Shift+Smart and the light should come on. Now you can do your smart loops. Without smart it relies on your ability to prefectly pick the 4 beats...
Roy
Roy
geposted Wed 18 Aug 10 @ 3:55 am
Thank you, I will try this...I believe the light is on from what I can remember but I'll double check & re-do this.
geposted Wed 18 Aug 10 @ 4:20 am
