Hi,
I'm fully paid up member of VDJ club with Pro version all licensed correctly. I'm about to remove windows xp and replace with windows 7. Is there a procedure I should follow to ensure when I install VDJ on the new operating system I don't run into licensing issues. At moment I am using both licenses, one on the XP machine about to be upgraded and the other on a backup machine.
geposted Tue 17 Aug 10 @ 4:04 pm
"No precedure " necessary, once you have installed and optimized windows 7, just install VDJ like you normally would..
geposted Tue 17 Aug 10 @ 5:46 pm
BACKUP THE CONTENTS OF YOUR VIRTUAL DJ FOLDER IN MY DOCUMENTS, especially IF you did all the work setting up VDJ!!!!!!
geposted Tue 17 Aug 10 @ 10:24 pm
Yeah back up your shortcuts, playlists, mappers... Everything, like he mentioned!
I remember loosing all my playlists I am still feeling it now... takes time to create these things ya know..
geposted Wed 18 Aug 10 @ 12:50 am
Thanks for the advice all. Just wanting to be safe rather than sorry. I've backed up everything in 'My Documents' anyway. Is there any links to optimizing windows 7 for use with vdj?
geposted Wed 18 Aug 10 @ 4:31 am
