Hi guys ,
i use the version 6 pro and was wondering if it is possible to assign the keys for the High, Low and Mid Equalizers separately for left and right deck. In my case i use the "E-Mu Xboard 25" which i would like to use as a USB Controller. Under Settings > Mappers the XBoard is selected as a "Simple MIDI Wrapper". Now the Problem : After assigning the 3 Control Dial's for the left and right deck, there is no way to use the controllers for the right deck as long as PFL for the left one is turned on. In other words if PFL is activated on the left and i try to use the dials for the right only left equalizers are affected. Is it possible to use all the 6 Eqializers ( 3 for the left , and 3 for the right ) at the same time ?!?!?
Hope you guys can help !!
Thnx
Thnx
geposted Thu 19 Aug 10 @ 5:03 am
So here ive uploaded a picture of the board to see what i am talking about :
http://d4rkv1p3r.lima-city.de/Expl1.jpg
When PFL is on the LEFT deck and i use the controllers for the RIGHT deck ( is marked red) the Equalizers on the left are affected.
How can i use all the 6 controlles separately at the same time ?!? Is there any way to avoid or disunite this PFL selection concerning the USB Controller assignment.
Sry for my english .)
geposted Thu 19 Aug 10 @ 5:37 am
ok , its solved , with the Generic MiDI Mapping .xml every Key was assigned correctly
geposted Thu 19 Aug 10 @ 10:02 am
