I´m using VDJ 4.3. After installing and uninstalling af few different versions it has stopped saving playlists.
Any ideas?
Any ideas?
geposted Thu 19 Aug 10 @ 10:33 am
is their a reason why you cant use the latest version of VDJ?
You may have corrupted something, hopefully you made backups of the original database?
geposted Thu 19 Aug 10 @ 11:38 am
Yes, I use 4.3 because it´s the most stable regarding time codes and reads BPM better than the later versions.
But it´s all versions of VDJ which has stopped saving playlist history, since installing and re-installing a few times.
geposted Fri 20 Aug 10 @ 10:41 am
