I use virtual Dj for pretty simple gigs. a problem i'm having is I want the TAB button to select the deck i want and automatically adjust the crossfader to extreme left or right corrusponding to which deck is active. is this possible?
geposted Thu 19 Aug 10 @ 5:20 pm
Sure just go into mallets and pick your key then type in what you want it to do.
Hope that helps
Huey
Hope that helps
Huey
geposted Sat 21 Aug 10 @ 8:58 am
Just press ctrl and page up or page down keys dependind on which deck you want.
geposted Wed 15 Sep 10 @ 3:35 am
