I've tried through the bpm analysis (right click track > bpm > analyze other music) and it gives me the bpm's but no key. Do I need a separate program?
I have version 5 rev 6 running on windows 7... Also the library I'm accessing is my itunes folder, maybe this effects it?
When I right click the track in my music folder I get these options:
preview
file infos
bpm > analyze other or techno/house or manual edit
file operations
remove from search DB
Any help would be much appreciated as I would like to try and mix harmonically
preview
file infos
file operations
geposted Fri 20 Aug 10 @ 11:57 am
Go to the title bar in the browser. Right click and it will give you a drop window.
Then just check next to the key, and it will show up.
geposted Fri 20 Aug 10 @ 12:42 pm
I've got the category open but there's still no key's detected for any tracks.
geposted Fri 20 Aug 10 @ 2:34 pm
as soon as you load a track or you press to search for bpm it will show key too.
geposted Fri 20 Aug 10 @ 2:53 pm
That's the problem. It's not giving me a key.
geposted Fri 20 Aug 10 @ 2:58 pm
It should be showing you something like this:
geposted Fri 20 Aug 10 @ 3:52 pm
...and that highlights another problem.
Why does VDJ show every song as being in a minor key?
Some songs are in major keys!
geposted Fri 20 Aug 10 @ 4:18 pm
Yeh, everything is setup the same BUT no key given where yours are :P would a screenshot of mine help? it's basically the same but no key
hello,
same version and problem. i'm on vista. i tried the solution here. no love.
geposted Fri 20 Aug 10 @ 4:26 pm
by the way appreciate the responses, this has been frustrating... anyone know of a program that can determine song keys? maybe I just need to use an outside source.
geposted Fri 20 Aug 10 @ 4:28 pm
i've tried beatunes and media monkey. i had better success with beatunes as it analyzes EVERYTHING and cross references with an online database. it even color codes the songs. vdj doesn't seem to support any of the imported data, however.
geposted Fri 20 Aug 10 @ 4:59 pm
I wouldn't worry about not being able to see it. It's absolutely useless. It thinks everything is in minor. They should take it out and stop wasting screen space until they work out how to build it properly. Mixed In Key is much better but, as far as I'm aware, doesn't plug into VDJ so you have to analyse your tunes outside and then go back into VDJ.
geposted Wed 06 Oct 10 @ 2:10 pm
