I am getting the start lag with the motors turned on that we had back in the day when the NS7 was able to connect up with VDJ. Is anyone else seeing this problem since updating to 6.1.1 No lag with the motors off and hitting the play button. Did anything change to cause this?
Funkmasterfrank
Funkmasterfrank
geposted Fri 20 Aug 10 @ 6:01 pm
If you are talking about play 'ramp up' ... then use the registry tool and put a check in the MotorWheelInstantPlay option.
geposted Fri 20 Aug 10 @ 6:05 pm
I'll try that but I just reverted back to 6.05 and it works fine again. I thought this was fixed for all updates after 6.05
geposted Fri 20 Aug 10 @ 6:18 pm
